Old 27 Oct 2009, 07:06 am
Default Re: New PT owner needs help with front brakes and maybe bearing replacement.
Welcome.
In my opinion, bearing would make noise all the time, so sure sounds like brakes.
It could just be the "feeler" on the brake pad, it's designed to make noise when pad reaches a certain thickness.
If you have alloy wheels, you can look thru the wheel at the caliper and get an idea of whether the pads are worn - if you have the steel wheels and to see both inner & outer pads, you have to take off the wheel.
If the brakes are original, at 36,000 miles it's time....
