Old 28 Oct 2009, 12:25 pm
AlTheKiller's Avatar
AlTheKiller AlTheKiller is offline
Default Re: Stuck in the mud
ill go take a look but my guess would probably be from the rear axle
Edit: yup thats where id do it. make sure its with a recovery strap and not a tow strap. the difference is the metal hook. you DO NOT want to use that for recovery. i know the PT is light but that hook can snap off and go through your window or worse into your head. ive seen it happen more times than i care to remember. also if the vehicle that is pulling you out has a tow hitch DO NOT use the tow ball. same thing can happen.
