  #27 (permalink)
Old 28 Oct 2009, 01:44 pm
2002Gold 2002Gold is offline
Default Re: PT Cruiser V-6 Conversion!
Originally Posted by RustysTouring View Post
Hi, I'm RustyTouring and I'm Cruisin in an 05 Tuobo Lite Silver Conv. I drove off a now shuttered Chrysler dealer in Far Rockaway Beach, NYC on Black Friday '06. I've been fasinated with rwd coversions of all types since Detroit went FWD in the eighties. I've always really liked the Buick V6 since there is plenty of non turbo power to be had. My rwd ideas consist of a 3.5 Dakota motor of whatever year your PT is (say an 02 Dakota motor if you have an 02, like our friend in Jersey). Wouldn't the computer work be simpler since you would be using the same manufacturer and year. Paxton makes a super charger if one was so inclined. The front suspension is a real BIG problem, and I see that you are fabbing the gas tank and I can only imagine the oil pan fitting day. I'm also cosidering a Prowler transaxle set up that I would just take to a reputable Street Rod shop as most have been putting Jag IRS rears in every thing from Duece Coupe to Willys Gassers to Model T's
for decades. Do you have room for Shorty Headers? To go from planning to actual cutting and fitting is really an impressive accomplishment. I'm new to the forum but I must agree that photos are an absolute must for any project let alone one of this magnitude. Good Luck, but I suspect luck ain't gonna have nuttin' to do with it. I'd fly to Hawaii to see this project! Take care.
Hi I'm back from Vegas. It was a very good trip! Yes, the Buick 3.8L, 231 cubic inch V-6 is a favorite engine of the V-6 family. It will be a good drivetrain conversion for me as well. I must admit that the Turbo PT, does hold it's own. I was amazed when I drove one for the first time. However, for me, I'm old school. When I pop the hood of a PT Cruiser, I much rather see a V-6 or V-8 RWD application staring me in the face. If you followed my thread from the start, you will note that I had installed a Chevy 3.8L V-6 engine from a 98 Camaro that did not turn out well due to numerous electrical problems. So, here I am now, installing a carbureted Buick 3.8 V-6 and a GM 200R4 RWD 4 speed automatic trans. Anyway, less wiring and no engine computer to deal with. Your Dakota 3.5 engine drivetrain sounds like a good idea. It does help if the drivetrain comes from the same manufacturer, however, one word of advice, do your homework to find out if the engine harness and computer that you chose to use are compatible. In other words, if you go with a computer from a 2002 Dakota, make sure you have the correct engine harness that is compatible with that computer. All though the years may be the same, the engine harness may be different. Some engine harnesses are built specifically for V-8 engine, some for V-6 engines, some with automatic transmissions, some for standard shift transmission, the list goes on and on. Just make sure you have the right part numbers that will support your ideal drivetrain conversion. For me, I'm using the stock PT Cruiser front suspension. I will provide pictures shortly explaining how I did that. The rear suspension will be a solid axle rear end housing from a 2002 Jeep Wrangler. I will be modifying it to a leaf spring suspension which requires less structual work. I will also provide pictures of my engine oil pan with the surrounding crossmember and other support structures. The engine oil pan will be able to drop straight down without removing anything else. That was one of my main concerns when I designed the engine and rack and pinion crossmember. I do have room for shorty style headers, however, they would have to be modified. The exhaust dump area, has to be up high and at the far rear side of the header to clear the top of the bell housing. There is no room for the exhaust to run under the bell housing. That is the reason why I'm currently using the exhaust manifold shown in the picture below. Later on, I will look for a set of shorty headers that can be modified to fit my application. Thanks for your comments and support. Aloha, Tommy.
