Thread: Belts?
Old 28 Oct 2009, 08:52 pm
Chromenut's Avatar
Chromenut Chromenut is offline
Default Re: Belts?
Oh, you didn't mention you were getting a squeal at speeds. Then you can say it's likely NOT your belt, or the belt may be a contributor. At speeds above 1200 rpms your belt usually won't squeal, it gets warm and stretches just enough to stop the squeal, in most cases. If you're in a freezing environment, the belt might squeal at speeds as it may not have time to really warm up.
If you're having "normal" PA weather (where in Pa? Just curious) and it's not yet late January, then that belt should stop squealing at speed if you've been driving for more than maybe 10 minutes. I'll PM you some other info shortly, but I'd say look at the tensioner. And be careful with the WD40 on the belts, it tends to break down the enamel in the spine coating of some belts. Of course, you'd really have to soak it to make a difference, but I'd still be slightly careful with it, don't overdo it.
With that GT you're producing more heat than the NA models turn out. I'd say that you probably should replace the belt anyway. I hope to heck it's not your power steering pump. Try sitting in your driveway in neutral, turn the steering wheel all the way left and hold it. See if the squeal gets worse, then try it all the way to the right. If it really gets worse, then you may need to have that pump looked at.
...if I only had a brain...
I would need my own forum just to list my mods!!!
Remember, a PT Cruiser is not just a car, it's a way of life!
LAUS DEO SEMPER
