Thread: "Wet" Plugs
Old 30 Oct 2009, 07:04 am
Default Re: "Wet" Plugs
Originally Posted by nevinsrt View Post
it could possibaly be a worn spark plug gasket on the valve cover. oil could just be seeping through and down the tube and as you unthread the plug oil is getting on the plug.
Look down the plug hole and if there is oil then that may be the problem. if you buy a new valve cover gasket you will see 4 circle gaskets, one for each hole. the gasket is easy to replace.
EDIT:
Felpro Valve Cover Gasket Set Dodge Neon SRT-4
That's my bet as well.
