Old 30 Oct 2009, 10:18 am
rubsnick's Avatar
rubsnick rubsnick is offline
Default Re: Crashed my PT, Need reparing but thinking of upgrading.
Originally Posted by Candyman View Post
Hey their Guys,
I wasn't aware Ray had done an update conversion to the older body style. Do you know what needed to be modified to update the headlight assembly, and front fasia in order to get a tight fitment, and more so how difficult was it to get the gap to align right? And then, if he was using the Bumperette, and Retro Grille combo, how much tweaking needed to be done their as well to get the front end aligned and gaped before final prep and paint? Many times whaen you change the configuration by updating, you could easily run into needing to tweak parts, or do slight modifications to correct for a proper fitment. The same usually goes for working with most Aftermarket parts as their could be slight inconsistencies, and so forth that may need to be corrected, or addressed to before final prep and paint. What I was getting at is, their are a lot of variables that may come up which could add to the cost of both materials, and labor to do the job correctly, and get a good outcome on the project. The more the materials, and time involved in getting things lined up as they should be, the more cost that could incur, so keep that in mind. Unless you already have experience in custom paint and body work, and have tried to install and gap parts that both are Aftermarket, and not year specific, then I would honestly say that you will more than likely have some more work involved instead of simply bolting parts on and go straight to paint.
As for your Fender, the $75 for your fender would be more consistent with either an Aftermarket Reproduction, or used part instead of an OEM CAPA Certified factory replacement which should run which should run you approximately $130 - $150 range. The big difference is the Aftermarket fender is basically a factory knock off made from a lot lighter less structural material, and is therefore cheaper than the OEM counterpart. It also will be much easier to dent, or could flex more than other parts due to its lighter density which if not prepped and painted to compensate could leed to paint issues down the road such as flaking off, and so on.
Then the last issue would be budget.
Lets say just for argument sake, you bought the Fender at your $75 cost, and had zero issues involved with the install, and then you got a good deal on your paint, for example getting the time and labor for free, and just pay for the materials involved. Here would be a quick breakdown of your project.
Fender:
$75.00
PTeazer Bumperette Front Fascia with Full Retro Grille
$1,140.00
Updated Headlight assembly Left and Right: Certified OEM Replacement:
$118.95, or $238.00 for the set.
surface prep materials, and a Factory Pack of waterborne Base/Clear Paint
to shoot the fender, complete front end, and blend the passenger front door, hood, and left front fender:
Roughly $400 - $500+ not including labor for the removal and disposal of the old parts, install of the new parts any fitment or related issues, time in the booth both for spraying, and for baking the base, and clear.
Total:
$1840.90
plus tax and shipping.
By the time you add the rest of the factors in, you will unfortunately be close if not more than double your budget to pull off the look. Please keep in mind, I am not trying to discourage you, but rather make sure you understand everything involvolved in a project like this. Anyways, for what its worth, that is my two cents into the mix. I wish you all the best in your repairs, and hope it all comes together good as new.
Go easy, and I'll catch ya later.
Candyman
Thanks for the advice but my father knows a guy who does great work. He has worked on my PT several times before and we already talked to him. He said that he won't charge more then 300 since it's simply paint new parts and put them on which is pretty simple. I sent Ray and email and I"m gonna see what he tells me about the whole deal. I actually found the replacement fender for $45 (my father knows people who sell autoparts) so that's a huge load off. I don't mind having a replacement fender and understand that they are well replacements. The grill and bumper cover set I understand the prices off and all that. Depdending on what Ray answers is what I do (and how much I get from the insurance) I'll also be getting replacement headlights (since I plan on modifying the buggers no use getting OEM's) So by getting them replacement I can get the set of 06 for 140 ish.
This guy that my father knows repainted my door and fixed a den't on it (made when some guy broke into my car and stole my backpack) I dent in the rear under the headlight (got it like that) and fixed the cracked bumper cover (it was cracked on the edges) this included Paint and taking stuff apart and he only charged $100 for it all. And he did a hell of a good job. Then he did it again when my bumper cracked for a second time (on both sides this time) he ficed it and added metal brackets so that the bumper wouldn't crack again.... HE did a fine job because the bumper didn't crack where it usually did (as you can see in the pics of the accident) for only $100 bucks. He also already has my paint in stock and all and is familiar with my car. So doing all of that will at most cost me $300. I'd be saving a good $400 by using replacement parts and stuff so overall I'm sure that It won't come out that expensive for me.
