Re: Check your tires
Very good idea. I gained probably 1/2 MPG last time I topped off the tires.
Here is a tip if you don't have a compressor at home. I got a air tank from Sears for under $20. It holds enough air to top off the tires. This will keep you from searching for the one local gas station that still has air. Also,handy if you get a nail and wake up to an almost flat tire.
Another, tip crawl under your PT and check you spare tire pressure. No one ever does. Mine was only 8 psi when I first checked it. I hope I never need it but It will save time and money if I do.
