Originally Posted by cjb15
Another, tip crawl under your PT and check you spare tire pressure. No one ever does. Mine was only 8 psi when I first checked it. I hope I never need it but It will save time and money if I do.
Yea - Don't depend on your tire shop to check the spare - they don't remember either.
Newer PT's must have a TPM system? I like it on my GM truck - before a trip a few pushes of the button on the dash and I know all 4 tire pressures.
Here's a check list I use every oil change on all my rigs as applicable:
Coolant
Air Filter
Battery/Belts/Hoses
Transmission Fluid
Rear Axle Fluid
Wiper Fluid
Brake Fluid
Power Steering Fluid
Wiper Blades
Brake Pads
Tire Pressure (Spare too)
Tire Tread
Lights
Lube Hinges (Annual)
Lube Weatherstrip (Annual)
