Re: 03 ptc randomly dies, electrical?
Thank you for your reply.
Only 3 keys on a ring (learned that the hard way), plugs and wires were serviced last summer. I checked the battery and cables that day. There was a great deal of corrosion around the post covering the terminal ends (golf ball size). After cleaning that mess, I tried to jump/charge the battery. It would not take a charge. (I had just purchased that battery on 3/24/08). Needless to say I had it replaced and was on my way, but still with this issue. Could a bad connection on the other end or break in the cables somewhere could be causing my battery corrosion issues, and should i just replace them all together? My brother drives a dodge and he received a recall notice sometime ago regarding a starter wire maybe, something like that. Being they are one in the same, should i look into that?
