Re: Types of Antifreeze we can use???
Originally Posted by SRG
You guys should try reading the owners manual:
From 2005 PT Cruiser Service manual:
CAUTION!
Mixing of coolants other than specified HOAT engine
coolants, may result in engine damage and may
decrease corrosion protection. If a non-HOAT coolant
is introduced into the cooling system in an
emergency, it should be replaced with the specified
coolant as soon as possible.
Do not use plain water alone or alcohol base engine
coolant (antifreeze) products. Do not use additional
rust inhibitors or antirust products, as they may not
be compatible with the radiator engine coolant and
may plug the radiator.
This vehicle has not been designed for use with
Propylene Glycol based coolants. Use of Propylene
Glycol based coolants is not recommended.
So basically is we dont use collant with Propylene Glycol we're ok basically? I use green prestone 50/50 prediluted. Says its safe to mix with any color coolant and safe for all cars.
My Love:
02' Gold PT Cruiser Touring: Pioneer DEH-P4000UB Reciever, Self built subwoofer enclosure w/pioneer TS-SW841D subs, Summit Turbo Muffler, Spectre Modular Air Intake, underseat neon lights, subwoofer neon strip lights, Intake Manifold Paint, exterior chrome trim, steering wheel cover.
