Re: 2001 Special Edition PT - Common Problems?
Just had mine flushed at 100K, $169 at the dealer (ATF+4). See if you can get your PT up on a rack and inspect the front wheel bearings, tie rod ends and struts. Look for any leaks that just might be starting. If you have fog lights, keep an eye on the multi-function stalk like QSD just pointed out. If you keep up with regular and preventative maintenance the PT should last you a long time.
By the way, what kind of "special edition" 2001 PT do you have. I didn't know they made any.
