Look at the first 2 files in this thread:
Speakers removal HOW TO
I can resume the process for you though.
1. Remove the power windows switch panel using a thin knife (butter) or something. Pry gently. Then disconnect the harness.
2. Remove all the 4 climate system knobs
3. Unscrew the Phillips screw behind the power windows panel
4. Pry out the center consol trim. No more screws, only some metal clips hold it
5. You will now see 2 Phillips screws each side of the first screw that you removed already. Unscrew them all.
6. Remove the "A" pillar cover. No screws, only metal clips involved.
7. Pull the dash cover to release the metal clips that hold it there
8. Pry up the front edge of the dash cover and then pull it toward you
9. You'll now see the keyless entry module in the middle of the dash
Done!
