Old 03 Nov 2009, 11:54 am
ptjoe ptjoe is offline
Default Re: Sudden drop in gas mileage
Originally Posted by CREWZIN View Post
The EGR and 02 sensors have a bit to do with the gas mileage but most of the time both things set off a fault code if they aren't working properly. You didn't mention the air filter, is it clean?
Air filter is new, Less then 1500 miles.
I was thinking a possible emission problem but as you pointed out, I should have set off a code...Is there a gas filter on this buggy?
What type of MPG should one expect from a Michigan cold start to driving local roads on average less then 3 miles each day?
Thanks
PT Joe
