Re: Timing Belt Broke?
Looks like it is the water pump. I noticed some water on the driveway under the timing belt side today. When I opened the radiator cap water came pouring out from under the belt cover. I guess the clunking noise was the pump falling apart. Could it be something else that went wrong in there?
If I use the kit below can I use the tensioner? It says first design. Wasn't there a issue with the tensioner that they changed?
GATES Part # TCKWP265B {Timing Belt Component Kit W/Water Pump; 4 Components (1 Belt, 1 Tensioner, 1 Idler, 1 Water Pump)}
W/Mech. Tensioner; 1st Design
