Originally Posted by SRG
Don't know about "wearing" out, but they DO go bad! On a 2003 we used to have, the pressed-on lug that attached to the starter went bad. Car wouldn't turn over sometimes, then would magically start. I tried cleaning the terminals and ground lugs. The problem got worse over time, until I replaced the battery cable assembly, that's when I noticed the problem on the end of the starter cable.
Chrysler sells the cable assembly as a unit, about $70 bucks if I remember correctly. It took about 20 minutes to do, unbolt the old one and put the new one in.
srg
My new-to-me 2001 PT (2.4L non-turbo) died in the company parking lot today. It appears that the positive battery cable terminal broke, right where it makes the 90-degree bend.
Is the cable installation something that can be done easily in the parking lot? I won't be able to jack up the car at all, so I'll be limited to what I can reach while lying on the ground.
And while I'm asking "basic" questions... what is involved in removing the air filter cover/etc to get access to the top of the battery? Looking at the shop manual (downloaded from a link on this site -- THANK YOU!) it seems simple, but sometimes what seems simple reading the manual isn't so simple in practice.
Thanks in advance for your help. This site is an amazing source of info.
-Tom H
2001 PT Cruiser
2.4L non-turbo
