06 Nov 2009, 02:28 pm
Re: Battery Cables and terminals
Originally Posted by Arne
My wife's PT, which I'll refer to as 'Hi Silver' from now on,
had the plus battery clamp half eaten away by the green gray corrosion.
aaaa.
This traveled an inch and a half down each red cable so what should have been a solid high amp connection was actually an intermittent dust clod.
Exactly. The corrosion works its way up the cable inside the insulation. And this includes the negative cable. And although most ground straps don't have acid corrosion issues, there can be some rust where they mount to the block and/or frame. If you're replacing one, replace 'em all.
Charliehorse
2010 Classic in Deepwater Blue w/Grey Interior
2008 Bullitt Mustang #901
