Re: overheating - a new question?
A little high on the price but hopefully it will get fixed right and you'll be on your way. Did they check for any other damage the pothole might have caused? Ask them if they bled the cooling system when they replaced the hose and make sure you test it out before you go too far away. Let it run with the A/C ON at idle for about 10 minutes. That would make it overheat if they didn't fix it properly.
