  #42 (permalink)
Old 07 Nov 2009, 05:48 pm
2002Gold 2002Gold is offline
Default Re: PT Cruiser V-6 Conversion!
Here's the new modified gas tank that I picked up yesterday from the shop. It is equipped with two roll-over vent valves on the top left, and right sides, and the sending unit and fuel pick-up tube is located inside of the middle recessed hole. The angle iron frame around the tank will sit flush with the trunk floor. Then the cover plate will be installed on the tank which will act as the new floor section that was removed, shown in the second picture below. The gas tank, angle iron and cover plate, is made of mild steel. The cover plate is 1/8" thick. The gas filler tube is welded in and is located on the other side of the tank. The mounting holes for the tank and cover have not been drilled yet. After I drill the holes, I will then be sanding, priming, and painting the tank and cover. Thanks for looking, Tommy.
