  #47 (permalink)
Old 13 Nov 2009, 02:49 pm
2002Gold 2002Gold is offline
Default Re: PT Cruiser V-6 Conversion!
Originally Posted by quicksilverdon View Post
It doesn't appear painted - aren't you worried about rust? I'd powder-coat it.
Yes, I will be correcting a problem I observed on the long side, of one of the angle iron pieces. It is not completely level. It has about a 1/8" downward bow in the center. Hard to tell by looking at the picture. It is the right side as you are looking at the picture. I need to correct this problem other wise it will place a warp in the floor. It must be as level as I can get it. Should be an easy fix. After I correct that, I will sand these items, prime them, then paint them. I generally use a high heat engine paint for items that are exposed to the elements. The bottom of the tank will be black in color, and the top section and cover plate will be gray in color. I would love to have these items powder coated, however, that option does not fit into my current budget. Thank you for your support and concern. Aloha, Tommy.
