Mine is bad about causing whatever is in the door "pockets" to rattle. I haven't cleared them out to see if it the problem goes away. The door panel is held on by screws at the bottom, torx head screws through the arm rest and spring clips. You may be able to put some self-adhesive felt on the door panel edges around the spring clip locations and see if that fills the rattle gap. Also, if you pull the panel, check to see that all the speaker mounting screws are tight.
