Old 30 Dec 2009, 09:00 pm
pclayton99 pclayton99 is offline
Default Re: Replace Multifunction Switch w/fog lamps
I took what KG posted for his 2001 Cruiser and added/updated various parts to reflect what I just went through on my 2005 Cruiser.
Old Part# - 04671870AD (2005 PT Convertible, Touring Edition, 2.4L Turbo, With Fog Lights)
New Part# - 05073049AB (dated 12/29/2009, same as back in 6/2007)
Cost to purchase at dealer - $142 including PA tax
Install time – around 30 minutes if you don’t stop to take notes and look things over.
Tools: Phillips screwdriver, small flat screwdriver, T10 & T20 Torx bits/screwdriver
• Put door windows down a couple of inches before disconnecting battery cable so you can open/close the doors without them catching on the rag top. Otherwise the top window edge catches in the recessed groove.
• Remove negative battery cable.
• Move steering column to lowest tilt setting.
• Remove (2) Phillips screws from underside of steering column plastic covering.
• Remove top and bottom covering and set aside. The top part comes off first, while the column is down. There are inside clips on the back end of the top/bottom covering that hold them together. If you push in at the back end (close to dash) on the bottom section you should be able to spring it free while lifting up on the top half. If not, carefully use a flat blade screwdriver from front to back to pop the clip. To get the bottom cover off, raise the steering column and it comes out much easier.
• The order of the next three steps can be *reversed* if there is not a lot of flexability to move the wiring harness around while the multi-function switch (MFS) mechanism is bolted in place.
• To disconnect the wiring harness, take a small flat screwdriver and push the red locking tab toward the engine, straight back. Do not lift on tab. It slides in and out.
• Disconnect wiring harness. Slowly. It should come out relatively easy. If problems, make sure red tab is pulled out as far as it easily slides.
• Remove (2) T20 Torx screws on top, close to steering wheel. Wiggle entire MFS off the posts holding the MFS so it can be moved around some.
• Remove (2) T10 Torx screws on right side by putting screwdriver through steering wheel spokes so the wiper switch can be disconnected.
• Pull wiper switch section out of your way to the right.
• Pull out old MFS.
• There was no dust cover on the 2005 model around the switch stalk.
• Transfer flasher module (not included with new part), on the side where the wiper switch was connected, by pulling it straight out/away from MFS. There are metal tabs on the back that can only be oriented one way to correctly insert it in the new MFS.
• Examine the two wires that come out the back of the MFS, snake around the edge (under hold-downs) and then up the middle of the switch stalk. Rearrange the wires to make it easier for them to move a little bit back and forth for when you move the switch stalk forward to engage high beams. I was concerned that having the wires tight would wear down the insulation and/or weaken the conductor. Don’t know what these two wires do but they do *not* control the fog lights.
• Place MFS back onto column, but not into proper position as you will need to install the wiper control.
• Install wiper switch with the (2) T10 Torx screws that were removed by once again reaching through the steering wheel spokes.
• Place MFS in the proper position on mounting posts.
• Install (2) T20 Torx screws into top mounting holes.
• Reconnect wiring harness. Carefully. Once the connector is fully pushed in, slide the red tab towards the steering wheel to lock the connection.
• Connect the negative battery terminal and test all functions of the switch stalk, 4 way flashers and wiper for proper operation. If any problems, *disconnect* the negative battery terminal and then check the wiring harness for being fully in place. Reconnect battery and try again.
• Install upper and lower plastic covers by moving the column down to put the top half in place and up to put the bottom half in place. Align and push the back ends (both sides) together to re-engage the locking tabs.
• Install (2) lower Phillips screws after aligning the front edge of the halves.
• Check that the column can still move up and down and that all switch functions on the MFS and wipers still work.
• Your done with only cleanup left.
Several other things to note.
• This part also goes under the number of “CBS-1210”. This number will fit a 2005 Cruiser.
• I suggest you pull the 15 AMP fuse for the fog lights from the inside fuse panel if you have any fog light problems in order to insure the lights don’t stay on and drain the battery. It is fuse #8 in a 2005 model. Check the back side of the fuse panel cover to ensure you remove the correct fuse.
• When the problem occurred and I had the fuse still in, headlights on and fog lights on (at least according to the switch position) the fog lights were not on.
• I also noticed that during this time, when I used the turn signals the display on the radio would blink in time with the turn signals.
• After I removed the fog light fuse, the radio display would very seldom blink when I used the turn signals. It always blinked when the fog light fuse was in place after the switch stalk problem started.
• I took apart the original factory installed MFS looking for anything glaring as to why the fog lights did not work. I found no broken parts inside the MFS. There is a plastic dowel down the middle of the stalk that works a leaver that pushes a metal contact up and down. The springs were good, the leaver worked, the stalk was not worn down or broken. There was oxide around one of the two contacts involved with the fog lights but I can’t tell if it was enough to stop electric from flowing. There was a lot of grease type lubricant on a lot of sliding parts inside the switch. Have to wonder about the electrical properties of the grease lubricant and if it was shorting things out or insulating contacts. Maybe it changes properties over time. Pure speculation on my part.
Anyway, my thanks to KG for posting his instructions and showing the way!
pdc
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
