Old 11 Jan 2010, 02:47 pm
THS_Cruiser03's Avatar
THS_Cruiser03 THS_Cruiser03 is offline
Post Re: Replace Multifunction Switch w/fog lamps
Hi PClayton, thanks for your reply. Thanks for confirming the stock fog lights are 55 watt.
Yes I agree with you. However I double checked my light kit and they are H3 bulbs at 55 watt rating (each) so I shouldn't have burned out harness issue.
Plus as a point of reference my xenons run 35 watts each (or 40 watts less than the draw of the stock Halogens) so I should be in good shape from an overall current draw perspective.
Is there a seperate fuse that runs the fog light circuit or is it on the same feed as the headlights?
In terms of replacing the base MF switch with the fog light version I think I'll just have the dealer do it (unless they want to charge me $400 labor) I need them to fix my trunk sensor anyway. Damn thing thinks the hatch is open all the time so my dome light is on all the time. Dealer already told me the sensor is probably bad. Though I bet it's just a mechanical issue that needs to be checked out - I don't open the hatch that much anyway (in my seven years of ownership probably less than 500 cycles which is NOTHING for a door life test BTW).
Tom
Base '03, Light Almond Pearl Metallic - Modified 2.4 na w/ported head, 10.4:1 compression ratio & Crane #10 camshafts - 4 speed - Energy Poly bushings - Napa ceramic pads & Ultra premium rotors - Rotora Stainless brake lines - Extreme Acc. Xenon HID 8k low & 6k high
Dark taupe & Ivory Interior, Factory CD w/Sirius Stratus 4, Power Acoustik 840w 4ch, Boss 200w 2ch w 10" bandpass sub, 2 sets Phoniex Gold Matched comp. speakers
Rolling stock: 16" SE A7w 225/50/16 Kuhmo Ecsta AST - One of the nicest Light Almond PT's you'll find
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
