quote:Originally posted by Jerry
OK. The Jet Chip was formulated to work with the automatic and one of the beauties of the chip is that it changes the shift points of the transmission. Now it shifts to low sooner and holds each gear longer. I won't dispute anyone on the horsepower gains but my 0 to 60 time changed the most with the installation of the chip. Believe it or not the chip was a better investment than the JBA header.
I don't see how it is possible for this specific "chip" to change the programmed funtion of the tranny.
What 0-60 times did you have before and after the install?
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
