quote:Originally posted by sakigt
Ok..Lemmie get this straight.
Stage 1 upgrades computer so you can run at 16.5 PSI w/o error codes?
So with my MBC, running 15 psi, getting codes...my engine is actually ok? Its my computer? [:I]
Most likely you're getting codes because the MBC causes high levels of boost at partial throttle. If you use an EBC, you can program it to reduce boost during partial throttle (connect to TPS reading) which will eliminate the error code.
