Old 07 Nov 2003, 09:00 am
dtbrks dtbrks is offline
Default Stage 2 info from SRT-4 site
Got this from the SRT site, hope they don't mind!
In the Mopar brochure I recieved this is what is said WORD FOR WORD (there are no pictures of the stage 2 or 3 uprades int he brochure).
STAGE 2 TURBO UPGRADE KITS --- SRT-4 AND PT TURBO
The Stage 2 Turbo Kits for the SRT-4 and PT Turbo give you a power boost of 265hp and 280ft-lbs. of torque on premium pump gas. For SRT-4, you can also achieve 280hp and 300ft-lbs. of torque on 100+ octane unleaded racing fuel. For additional power and a more aggressive exhaust note, you can add our new Cat-Back Exhaust System (see page 26 for details).
*Stage 2 PCM
*Turbo toys (SRT-4 only)
---Turbo Intercooler Sprayer
---High Octane Fuel Switch
---Dial-A-Boost "Down" Switch
---All necessary wiring, switches and mounting hardware
*(4) 682cc/min fuel injectors
*Wastegate actuator
*3.0 Bar Map Sensor
*3.0 Bar TIP Sensor
*P5007863 2003-04 SRT-4 Stage 2 Turbo Upgrade Kit
*P5007946 2003 PT Turbo Stage 2 Upgrade Kit --- MTX
*P5007945 2003 PT Turbo Stage 2 Upgrade Kit --- ATX
*P4510257 2004 PT Turbo Stage 2 Upgrade Kit --- MTX
*P4510258 2004 PT Turbo Stage 2 Upgrade Kit --- ATX
STAGE 3 TURBO UPGRADE KITS --- SRT-4 (late availability)
For maximum power and torque --- target is 300hp/300ft-lb. of torque --- Stage 3 Turbo Kit is the ultimate upgrade for your SRT-4. Includes all Stage 2 components plus the following upgrades:
*Stage 3 PCM
*TDo5HR-15k2-10cm2 (2 is for squared) turbo unit
---16% larger compressor wheel diameter to flow and compress more intake air
---19% larger turbine wheel diameter to flow more exhaust gas and reduce back pressure
---67% more turbine scroll area for reduced back pressure
*High-flow (75 psi) fuel pump module
*Demand-regulated fuel rail assembly
*P5007864 2003-2004 SRT-4 Turbo Upgrade Kit
*P4510256 2003-2004 SRT-4 Stage 3 Add-on Kit (for vehicles with Stage 2)
