Old 27 Apr 2010, 11:26 pm
nomad327 nomad327 is offline
Default Re: Question on GT Convert Wheels
In 05 at least, GT's all had 17's, basic models had 15's and midlevel cars including turbo's and all non GT convertibles had 16's. Most GT's seem to have chromed aluminum wheels and some 16" wheels came in chromed versions. I have an 05 PT touring that had the basic brakes and 16" painted 7 spoke wheels. those wheels appear to be the most common on 05 touring convertibles. I have put the GT discs and calipers on my front axle, and they work just fine with the 16" wheels. The overall diameter is not any bigger, the rotors are much thicker than base rotors, and the calipers are then wider to match them. A useful upgrade, as I felt the stock brakes were a little weak. Any 16" or 17" Chrysler built wheel should clear the GT brakes, 16" aftermarket you may need to try on the car. I believe some people were having trouble with the chromed wheels deteriorating at the bead and leaking air. I had that problem on an eclipse I had. I prefer non chromed wheels. If you do get chrome wheels, tire stores have a gummy black brush on compound they can put on the beads if the chrome starts to flake off of the aluminum.
