quote:Originally posted by tezz
Okay - it's back at the shop - in the meantime - the only code that came up was "P0016" - any idea what it means? The service tech/intake guy didn't....
tezz
P0016 - Crank and Cam out-of-sync
Set Condition: No Crank Sensor or CAM Sensor Electric DTCs present.
If the CAM Signal is in the Low State: No CAM Sensor polarity charge between 17 and 40 crank teeth.
If the CAM Signal is in the High State: No CAM Sensor polarity change between 77 and 100 crank teeth.
From the 2003 Powertrain Diagnostics Manual Page 28. Your dealer failed the test.
