Old 08 Jul 2003, 12:34 pm
DTs_PTGT DTs_PTGT is offline
The manual says you should use 5w-30 if you drive in temperatures that don't exceed 100 degrees Fahrenheit. If temps. get above 100 degrees then you should use 10w-30.
Considering you are in NH, I would say go with the 5w-30. You will get less friction which will give you more HP.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
