  #11 (permalink)
Old 12 Jun 2010, 03:21 pm
CREWZIN CREWZIN is offline
Default Re: 2003 pt cruiser overheating
Bad news. Don't even attempt to do the timing belt and water pump yourselves if you've never done anything like that before. It's a very tricky/complicated procedure even for an experienced mechanic.
Personally, I can see your frustration but I've never heard of the timing belt causing the overheating problem. I haven't looked over all the older posts on the thread but overheating while your moving is basically telling you (1) the air isn't getting through the radiator/condenser, (2) the coolant isn't flowing around the engine properly when the engine needs it the most (moving), (3) the head gasket or head itself has a crack.
Have a compression check to rule out the last one. Make sure there's no air in the coolant system that would stop the coolant flowing around. Verify the water pump is flowing the coolant around.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
