Old 14 Jul 2003, 01:31 pm
Ian-PT-GT Ian-PT-GT is offline
A friend of mine gave me one trick he did for his PT to remove the reflector without opening anything.
Use a screwdriver and pry off the reflector.
Then, insert a needle nose plier thru the bulb hole and pinch the reflector until it breaks. You will have to break it into a few pieces then take them out thru the bulb hole and you are done.
I will try this next weekend.
Ian
