i think there a slight differences in the shaft running from the linkage to the knob, i.e. the chrome part you can see. The difference being the bend that is visible if you pull the boost down. Therefore, the "short throws" will most likely fit. But a "true" short throw probably will not due to the fact that the n/a tranny has R on the bottom right, and the '03 Getrag is top left.
So, if your just replacing the shaft then yes is should work...BUT i'm not 100% sure. Try contacting Hurst by email, they're usually pretty good with info
My Cruiser is slow. I love the law.
