Old 31 Jul 2010, 07:22 pm
CREWZIN CREWZIN is offline
Default Re: 01 pt cruiser radiator fan not working HELP
Salteedog,
As Doverdale found out, sometimes it's not a part that can easily be replaced but something that's not part of the equation of how the fan works like a bad wire. The two things you haven't tried (but mentioned one) is the ECT (Engine Coolant Temperature) sensor and the computer. They both have parts to play in operating the fan and keeping the car cool.
One thing to tell you is that when you hear the compressor going on and off repeatedly, it possibly means your low of R134a so yo want to have that checked.
Also on the overheating; are you using the right coolant in the radiator and at the proper 50/50 mixture? Are you sure all the air is out of the system?
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
