Old 01 Aug 2010, 08:17 pm
CREWZIN CREWZIN is offline
Default Re: 01 pt cruiser radiator fan not working HELP
Paula,
Overheating when moving is usually one of two things. The coolant isn't circulating throughout the system (clogged radiator, air in the system) or a problem with the head gasket or head itself (either could be cracked).
Hubby is working on the right stuff but there's equipment to tell if there's internal damage without pulling everything apart so look for a mechanic with the right test equipment before spending serious money.
Unfortunately you can almost never tell why someone gave up their car and there's all kinds of things that can be done to make it run for awhile before problems will show up for the new owner.
Sorry you had to pay $125 for the thermostat but there's a bit of work that has to be done to change it and probably an hour or so to diagnose it, so depending on the hourly rate of some dealers, you might have got away cheap. My closest dealer is $90 an hour so it would have been closer to $200 if you had it done here. ...just trying to make you feel better.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236
