IMHO, it would probably be cheaper to go to your local muffler shop and have them build a custom Stainless Steel system for you or at least replace the front pipes, and you could probably ask for stainless tubing in the stock or OEM thickness of 16 gauge or thicker instead of the 18 gauge most aftermarket systems are using. Muffler choice is up to you (stock or aftermarket), discuss your requirements with your muffler shop. If you replace the front pipes, buying or adding a Euro system (most are axle back and stainless steel, plus meet europe's strict noise laws while allowing a relatively free flow exhaust) is another alternative. For a dual pipe system, Remus, part# 116000-1580TD; MS-Design, part # MSES.CH.20.00.0656; Laser, part # 90.84005MM; etc.
Remus
MS-Design (Note: either side can be independently adjusted for height/clearance and the pipes are powder coated black)
Laser
