Old 18 Jul 2003, 12:17 am
PTGT Redman PTGT Redman is offline
Thanks for the info. So, Dalite, for the power tap for the light in the gauges which fuse(s) would you recommend?
For the gauge power?
Where is a reliable ground for the other wires?
Thanks.
If I drill for the pyrometer in the cuff after the joint in the exhaust, should I try to drill on the upper side or side of the pipe?
Thanks.
Oh I forgot, the boost gauge kit comes with a MAP sensor. where is a safe place to mount this along the firewall?
Rob
Homepage:
