Garlin,
Did the stutter start right after the installation of the K&N? Did you put in in yourself? Maybe a connection was left off. There's two connections that go into the filter...one is a sensor that measures the air density and has a very small delicate tip, check to see if that has broken off. The other connection is a feed back black plastic tube that runs from the right side of the engine to the filter. Make sure it's connected well into the K&N tube. Just something to check...good luck.
