I have relocated mine to the plastic cowl below the hood. I used some adjustable washers made by Mycarr (purchased on the Midnight Moose Web Site-www.midnightmoose.com). I used these because they are very adjustable and I could adjust the spray where I wanted it on the windshield. I drilled 2 holes in the cowl(s) and mounted the washer nozzles in the holes and used the nuts to secure them. Then I drilled a hole in the firewall by where the washer fluid tube is routed up to the hood. I ran the fluid tube thru the hole (sleeved w/some hard plastis wire wrap to keep from cutting or abraiding the tube). Put an in line T fitting and ran to both washer nozzles. Ran tubing longer than I needed so that if I have to remove the cowls again there is enough slack to do so. I don't have any Pics of this but I'll see if I can get a couple & post. I replaced the nozzles on the hood with washer nozzles w/bright blue LEDs and did not connect the nozzles. I just got tired if the nozzles peeing on my hood and leaving tracks. If they leak a little now its no big deal, because it goes into the channel under the cowl and drains out like rainwater does. And I like the blue eyes on the cruiser. Only problem is they're illegal in PA, so I put them on a separate switch so I could turn them off/on when I feel the need too. Apparently the ornamental lighting statute in PA is open to inerepertation. I talked to Yobiebs who spoke with a statie and they said they're OK, but I got a ticket from a local county yokel for ornamental lighting. UGH!!! [8]
Alan
