Old 02 Dec 2003, 11:33 am
Default How to apply dressing
First you can read my post on the prior thread (tire dressings) now I will add a little. Most of you know that I track all comments on my products, and try hard to ensure ALL are satisfied. Recently I had a person buy one of all my products and his feedback was all fantastic, but my dressing was average. I asked how he applied it and it was done incorrectly. he sprayed it on a dry tire and removed it with an applicator pad. WRONG. Here is the correct method. Tires should be clean and WET. yes wet, while it is wet, you spray on the dressing (don't forget the wheel wells.) applying or removing with a pad or rag only takes off 50% or more of the dressing. allowing it to air dry permits the product to soak into the rubber. water based dressing actually gives new life to tires when applied correctly. (opposed to solvent which destroy rubber) as the product evaporates, you will see a HUGE satin finish appear before your eyes,. I'm sure I have that on the label as well. but I wanted to post this just so everyhone knows. Gary
