Old 02 Dec 2003, 11:56 am
Default Where to use cheap wax
I wish I had a nickel for every bottle of product I used once and is sitting on my shelf. I thought I would share with you where I have found a place in my shop now for cleaner wax. As you know the first word "cleaner" means just that. It has more abrasives in it than protection. Under the hood area , and side area which is painted along side of the engine is perfect for using a cleaner wax. Unless your engine looks like Crewzins (which is perfect all the time)it does get subjected to the dirt, and grime from the engine components. By cleaning this area on a regular basis with soap and water, and giving it a cleaner wax application, it will look better longer. It has enough abrasives to clean, and just enough protection to seal out most dirt. the key word here is regular maintenance. Gary
