Old 30 Nov 2010, 05:19 pm
cruserdad1976's Avatar
cruserdad1976 cruserdad1976 is offline
Default Re: Transmission leak
yes you can replace the seal between tranny and the motor
you can also replace the seal on the tranny pan
But if it is your rear main seal then it is usally gonna be your pump and then its just best to do the complete job
at 102xxx its not that uncommon but some have went a lot farther.
did you ever have the tranny flushed??? does the tranny slip??? shift hard??? miss gears???? a lot of city driving? highweay miles? if it is just a leak then you might be lucky and just need a seal replaced there are several that can leak on the PT
a tranny job is usally n the teens depending on where you are located
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
