Old 04 Dec 2010, 08:37 am
tryingbe's Avatar
tryingbe tryingbe is offline
Default Re: another pt cruiser with issues.
According to the service manual.
Compression Pressure : 1172-1551 kPa or 170-225 psi
Maximum variation is 25%
(9) Compression should not be less than 689 kPa (100 psi) and not vary more than 25 percent from cylinder
to cylinder.
If you're sure you have fuel and spark. Drop a tea spool of oil into each cylinder to bump up the compression and try to start again.
85 GLH
Watch out for anchor engine mounts!!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
