Thread: ac compressor
Old 02 Aug 2003, 04:58 pm
yellowpanel yellowpanel is offline
There are 2 connectors on the compressor. At the top on the side nearest to belt you will find a black connector with a black wire and a Medium blue wire. Black is negative, blue hot. You need both! On the other end is the pressure switch. The compressor will cut off if there is low charge, this is most likely your problem.
mike@trickcruiser.com
www.trickcruiser.com
