Thread: prejector lamps
Old 05 Aug 2003, 10:35 am
TripleJackInGA TripleJackInGA is offline
Do you want specs, etc. for the 90mm Hella lamps, or the OE headlamps? I can't get you anything on the OE lamps, but you can see specs, drawings, etc. on the lamp modules that I want to use on our web site at www.hellausa.com.
Yes, the TYC lamps are nice, but you have to remember, they are making them as an assembly, in a plant, and the ones we are talking about would be fully custom.Yes, I will be painting the inside of the reflector area flat black, and the outer reflector possibly black or color matched to the car.
The inner reflector is mounted in the housing using 3 nylon mounts, and if I can get an engineer here to do a cad drawing of a bracket utilizing these mounts for my lamps, I can just have a bracket made that will incorporate the factory mounts, and therefore adjustability, with the new modules.The only problems is that these lamps would not meet SAE certification when they are placed behind the OE clear lens.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
