Old 05 Aug 2003, 04:59 pm
Cal Cruzer Cal Cruzer is offline
I would pull the interior trim off of the hatch to see if it is reinforced anywhere on the inside and if so use that as a point to drill through. I cannot think of any other way than that or as suggested above. YOu will have to hurt the hatch a little if you don't think the wiper/handle idea will work for you. I would check and see how the wiper motor is mounted to see if it has a hard attachment to the window. You may be able to use the one shown above.
Good luck
