quote:COP TZER wrote:
higher boost... can be achieved with a MBC/EBC
snappy exhaust can be achieved with... a cat back system
If you want boost to hold over shift... buy a better wastegate actuator
Can you buy all of this for $399? Get it installed
and fully dialed in in 2 hours?
quote:the car runs rich as it is, therefore an increase in boost would bring the car to ideal running conditions.
"Ideal running conditions" as defined by what? There are other things to consider beyond torque/power output. How 'bout exhaust valve & seat temps, turbine temps, exhaust manifold temps, exhaust catalyst temps, detonation, cylinder pressures, fuel octane/quality?
quote:The pop-pop occurs when a car is running rich and is igniting in the exhaust...there fore more "pop" means too much fuel and unoptimized air fuel mixture
Maybe they're just retarding spark??? Several SRT guys report getting
better mileage with Stage 1 than stock!
http://www.srtforums.com/forums/show...&threadid=9020
quote:-i'm still confused as to how you can optimize a motor for a specific BOV by changing the software and injectors...if anything, i can see it optimized for ANY bov.
Most aftermarket BOV's are purely mechanical (spring/diaphragm device plumbed directly to manifold pressure). The stock valve is electronically actuated. This means the ECU decides when to open the valve and for how long. I'd guess they calibrated it to be very quick reacting (using throttle position???) and kept an eye on maintaining reasonable duration for each event. These types of electronic changes will have NO effect on a mechanical BOV
unless it's integrated into the stock setup... like the Mopar conversion kit.
