Thread: Boost
Old 15 Aug 2003, 12:58 am
ElectricBlueGT ElectricBlueGT is offline
At58,
Does the car seem to be running better? I mean, does the Stage 1 kit seem to be doing the job? If yes, then it would appear that there may be a problem with your boost gauge, boost tap, or line to the gauge from the tap. If no, then I would check to make sure that all of your vacuum lines and hoses are ok (tight, no holes, etc..) and check your boost tap and line again. From what I have read and understand, you should be generating a lot more boost, particularly in first gear. When the Stage 1 kit was installed, a lot of hoses were disconnected. Check to make sure everything is intact and connected properly. Let us know what happens.
My two cents,
Scott
\"If you choose not to decide, you still have made a choice.\"
