Old 27 Dec 2003, 11:12 pm
IRPT IRPT is offline
Default X-treem Metal Majic
Just wanted to pass this along. If you have not used this product you should try it out, works great on polished aluminum and chrome, shines and protects. Metal Majic is a sealant for metal surfaces. I first used this on my Harley, lots of polished aluminum (what a pain to keep shined). After using Metal Majic my polished aluminum stayed polished!
The only place I found it in my area was at a bike shop, I've listed some links before where you can get it online, if interested.
Info:
The name says it all. The little miracle that gives the finishing touch to all polished aluminum, brightens chrome to a deep luster and keeps the water spots away. Metal Majic is also great on clear coated and painted wheels. It even removes metallic brake dust that "bonds" to your painted, clear coated, or chrome wheels! Try it once and you will use Metal Majic for the life of your car.
Because Metal majic is not a wax, the sealant needs only a single application to achieve 100% protection. Reapply Metal Majic as needed. Average time between application is 45-60 days. Additional polishing should not be necessary for 3-4 months. Metal Majic is ideal for cleaning & protecting clear coated wheels.
http://www.cecodist.com/03001.htm
http://www.1010tires.com/accessories...egory=Cleaners
http://www.rainorshinewpm.com/x-treem_products.html
