It is noticable but more so for those walking down the street if you lift off the throttle as you pass them by. The BOV also allows the turbo to re-spool faster and there was another post recently stating they could tell the performance differance between driving Stage 1 without the BOV and then adding noticable performance when they did the BOV install. MOPAR also claims Stage 1 is tuned for the BOV. It's not that hard to remove if you really don't like it...
Deen
