DYNO RUN
I've set up an appointment for this Friday to see what the car is doing. I have stage1, 2.5" CAT back exhaust and the factory airbox. The first run will be with this setup and the next run will be with the K&N Typhoon installed. I would appreciate any suggestions on additional items that I should check. I will of course post the results, good or bad. Hopefully, I'm making at least 240HP minus whatever loss % that goes to the wheels. Are there any other things that I should check, during my hour of dyno time?
TIA
macster
