Redman are you running any kind of MBC ? If not then your PCM is holding /bleeding your boost . I'm still running my $50.00 MBC off solenoid #2 . If I disconnect MBC, my turbo 5-speed would get to about 11lbs and slowly bleed down . This isn't the case with the MBC . I'm adjusted to 12-13 lbs and hold as long as I'm in the throttle . Boost starts @ about 1/3 throttle. Wish I could help with pyrometer issue but unfortunately I don't have a clue ![:I]
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
